mdl95003 Posted November 2, 2010 Report Share Posted November 2, 2010 I am replacing rear brake pads; rear left pads were worn to 1mm. Rear right pads were worn to 4mm. The calipers have the same part number, but the right rear caliper has a difference in casting thickness and slight differences in appearance. When I installed new pads and reinstalled the caliper on the left side, it has a perfect snug fit on the rotor with piston fully retracted. When I attempted to install the rear right caliper with new pads, the pads are too thick and won't fit over the rotor even though the piston is fully retracted. Are there supposed to be different pad thicknesses installed on the rear right/passenger wheel as opposed to the rear left/driver-side wheel? (Caliper assemblies have the same part number on rear right to rear left, but the casting is slightly different thickness/appearance on the rear right as opposed to rear left--I don't know the service history, as I am the 2nd owner, and the dealer service history shows rear brake service at different intervals, but doesn't indicate whether rear right rotor was replaced, which might be a source of this issue?) Any advice/experience similar to this? Quote Link to comment Share on other sites More sharing options...
AnthonyF Posted November 11, 2010 Report Share Posted November 11, 2010 I am replacing rear brake pads; rear left pads were worn to 1mm. Rear right pads were worn to 4mm. The calipers have the same part number, but the right rear caliper has a difference in casting thickness and slight differences in appearance. When I installed new pads and reinstalled the caliper on the left side, it has a perfect snug fit on the rotor with piston fully retracted. When I attempted to install the rear right caliper with new pads, the pads are too thick and won't fit over the rotor even though the piston is fully retracted. Are there supposed to be different pad thicknesses installed on the rear right/passenger wheel as opposed to the rear left/driver-side wheel? (Caliper assemblies have the same part number on rear right to rear left, but the casting is slightly different thickness/appearance on the rear right as opposed to rear left--I don't know the service history, as I am the 2nd owner, and the dealer service history shows rear brake service at different intervals, but doesn't indicate whether rear right rotor was replaced, which might be a source of this issue?) Any advice/experience similar to this? New pads lining thickness should be 12mm. Check the sliding pins of the torque plate(caliper bracket) Quote Link to comment Share on other sites More sharing options...
