Coilpack Location
2ndTwin
You must have the European model. The RX300 built for the U.S. market only has 6 coils; one for each cylinder.
Coil pac # 7 ??? Do the europeans start counting at 2 ? Never heard of an RX with more than 6 cyl. :rolleyes:
i have a check engine light code P1330....This is Igniter circuit malfunction (no. 7).........#1.which is open or short,,,,#2 failed ignition coil/ igniter,,,,,,,,,,# 3 ignition secondary fault
Car runs fine .....Can i reset check engine light without reader?
