Max Power Posted October 14, 2010 Posted October 14, 2010 Does anyone know FOR SURE which nozzles fit on the 90-92 LS400's? Other than nozzles from the 90-92 LS400's... I just bought a set from a 2001 LS430 and they don't fit. Thanks!
steve2006 Posted October 14, 2010 Posted October 14, 2010 Hi, Model years from 1990 to Oct 1994 have the same part # 85035 85341-50010-?? (?? depends on the color required). The later models have a different part # so should be different and therefore not fit.
Max Power Posted October 14, 2010 Author Posted October 14, 2010 I am asking because I had read that many people had been upgrading to newer model windshield washer nozzles due to better spray patterns. I had also read that almost any pre-2006 model lexus nozzles were interchangeable. The LS430 ones being preferable. Just wondering if anyone had any info on that.
RDM Posted October 14, 2010 Posted October 14, 2010 Are the LS430 nozzles close enough that if you trimmed the hole out, they'd fit? On the Nissan 240SX the later 1997-98 models are larger than the 1995-96, people just trim the hood with a dremel just a hair to accommodate them. I'm betting the LS is similar.
Max Power Posted October 14, 2010 Author Posted October 14, 2010 Nah they weren't. The hole on the 400 is actually bigger. So the nozzles wouldn't stay put. Not really close either. I could always use something to make it stick. However, I'd rather just find some that fit properly.
