s2tae Posted October 13, 2010 Share Posted October 13, 2010 Hi I own a GS430 with 110,000 miles. The car doesnt have any problems but since its past 100k i thought i do the usual timing belt, water pump, tensioner, and 2x cam seals in the car. I am mechanically inclined enough to do the job except for one thing if anyone has a diagram, picture, link, or can describe how the cam gears need to be lined up or marked before and after timing belt is installed. Also if anyone had done this and know any do and donts that would also be appreciated. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
intakerGS Posted October 13, 2010 Share Posted October 13, 2010 This should get you started: timing belt man Can't recall any do or donts at this time, as it is a rather straight forward job. Quote Link to comment Share on other sites More sharing options...
AnLex01 Posted October 13, 2010 Share Posted October 13, 2010 Hi, LS 430 has the same engine, pls find LS 430 timing belt change advices on http://www.clublexus.com/forums/ , there you can find the pictures of the all work phases. with good hints, too. Anlex Quote Link to comment Share on other sites More sharing options...
