Power Window Switch Caps
codeThug
Fellow Drivers,
Most of my power window switches are failing on my 190K mile 470. The little black plastic rocker caps that engage the "actual" window switch are cracking and breaking at the pivot hole. So in essence 25¢ worth of plastic is about to cost me probably at least $120 per switch to fix. Any way around this other than to replace the entire module or spending hours whittling one out of hardwood? Thanks.
-steph
It is the switches on the driver's door, correct?
Your best bet is to replace the whole thing, try searching on ebay for a used, but none broken one, thats what i did.
When i bought my LX, 3 out of those 4 black plastic switches were missing, so i had to replace the whole thing.
It actually took me some time looking for one, almost 8 months! but finally found one on ebay for $80!!
Easy as is, just took my old one out, simply put the plug in the new one, there's my perfectly working new(used) windows/door lock switch!
