jolsamuel Posted October 9, 2010 Share Posted October 9, 2010 I have a 98 GS400 and I have 20x7.5 wheels on it with 225/35/20 tires on front and 245/35/20 on the back and my power steering is hard when the car is parked and when its moving I flushed the fluid and my tire pressure is 40 psi on front and like 30 on back. What may be the cause of this problem, is it the tire pressure or the difference in tire width, the wheel does not weight that much either. If you have this same model and year, Is it that hard too? Quote Link to comment Share on other sites More sharing options...
intakerGS Posted October 11, 2010 Share Posted October 11, 2010 Can't imagine it's caused by your tiresize or pressure, as you state it's also hard when moving. I suspect a leak or something wrong with your steering rack, valves, seals or hydraulic pump, perhaps there's air in the fluid. Quote Link to comment Share on other sites More sharing options...
Rager Posted October 12, 2010 Share Posted October 12, 2010 I had/am having the same problem with my year 2000 GS 300. First thing was to install a filter in the return line to the reservoar, that removed the uneven power steering (and protects the rack in case of pump disaster). The core of the problem could be in the solenoid at the P/S pump, however it is not sold separately. It is getting better if you excersie the solenoid by disconnecting it and apply shortly 12 V directly to the solenoid, there is a connector at the cable down at the side of the engine under the P/S pump, apply 12 V for just a second, several times, change polarity each time. You should hear a clicking sound from the solenoid, otherwise, it is stuck. An improvement for all GS:es before year 03, is to replace the P/S control module under the dashbord and install the one for the 03, it provides 0,5 - 1,0 V more on the solenoid. Of course, won't help if the solenoid is completely stuck 89650-30610 is the part number for the ECU out of the GS Sport Design in 2003, price 278 USD. That is an improvement for all GS:s, also when your car is not having a problem. Further improvement can be expected by replacing the P/S fluid with "Red Line Power Steering Fluid", or similar compatible high performance fluid. If that doesn't help you have to go for a complete new P/S pump, very expensive. The rack is probably ok, if you haven't been driving around with a P/S pump that is completely run down, then all the metal fragments would have ruined the seals in the rack. Good Luck Rager Quote Link to comment Share on other sites More sharing options...
kevinjones Posted October 21, 2010 Share Posted October 21, 2010 First of all, you can check the tire pressure. All tires must be equal and the air is filled according to the manufacturer recommends, PSI. The wrong amount of air in the tires, especially if they are too low can result in severe and rigid steering.The back and my power steering is hard when the car is parked and when I washed the fluid motion and my tire pressure is 40 psi front and rear. Quote Link to comment Share on other sites More sharing options...
