mccldwll Posted October 5, 2010 Share Posted October 5, 2010 On '05 RX330, the rubber piece which hides the body color on the B pillar between the front and back windows ripped and to fix it's necessary to replace the entire piece which is on the front edge of the rear window (the shiny black piece).I've bought the piece. It's primary attached with peel off adhesive strips on the back of the moulding, but there is a small plastic notched piece which appears to fit inside something. Has anyone replaced this? Does it simply slide down into place before the piece is pushed back to adhere? Thanks. Quote Link to comment Share on other sites More sharing options...
joe913 Posted October 5, 2010 Share Posted October 5, 2010 don't know about the 330 but you might get an idea by looking at the document at the following link: http://www.box.net/shared/o55c5697lt#/shared/o55c5697lt/1/9328827/92954531/1 Good luck! Quote Link to comment Share on other sites More sharing options...
