Intermittent Whirring Dashboard Noise
TARPON
It is usually the HVAC system's servo motors hunting for position. Most folks describe it as a "bubbling" sound. Search this forum using "servo motor noise" as your key phrase and you'll find plenty of information on it....
It's the little geribles in the cage up under the dash. They get restless after a while... least that's what it sounds like. It is indeed likely the servo motor(s) going bad. What I discovered is the motor on the lowest 1 gets weak and can't get the "over-center spring" over center. It doesn't do it in any of the other positions because it only has to try and "over-center" that spring in one mode position. You can get rid of the noise if you want to, but it may not blow out of the center dash position, or you can put it in the position you want and unplug it. Neither are ideal choices but they WILL get rid of the noise.
thanks for your response
thanks for your response.
