creamerGS300 Posted September 9, 2010 Share Posted September 9, 2010 I'm having trans problems with my 93 gs300. I know what its gonna take to get it running but I am curious. If i could get ahold of a manual transmission from a 2jz supra would that bolt right up and work with out much modification. I understand i would need to figure something out with the shifter area and that's no problem but will i need to do anything with the ecu in the car and the drive-shaft? Not sure if anyone knows these answers but any info would be a great help! I want to do this cuz auto transmissions are such a pain and manual trans is so much more simplistic thanks so much for your time in reading this -jerry Quote Link to comment Share on other sites More sharing options...
TRDGS300 Posted September 22, 2010 Share Posted September 22, 2010 auto to manual? pain in the !Removed!. be ready to pull out the motor to drill the clutch hole, connect shift linkages... etc... just get an auto tranny. or swap an auto gte into it. labor is extensive for the auto to manual conversion. Quote Link to comment Share on other sites More sharing options...
