Replacing Rear Combination Lamp
I broke the clear plastic cover of the LH rear combination lamp assembly on my SO's '10 RX450h. (How I did that is so stupid, I'd rather not go into it.) Two questions:
1) Where can I get the part cheap?
2) Is replacing it as easy as similar parts with other cars: Just pop off an interior panel, undo a few bolts, then install the replacement?
If it's anything like the Rx400h, pretty much.
Try ebay or car-part.com. Or for new, try parts.com.
You may want to find out if the Rx350 lamps are the same as the Rx450h. I know for the 06-08 Rx400h they differ from the 04-09 Rx350 lamps, but it "appears" that for 2010 the hybrid and gas-only engine models have the same tail lights. It may give you more options for buying used.
I looked at it. There is an access plate to change the bulbs. However, the next step to take is not obvious. How does one remove the panel piece behind the lamp?
