Sign in to follow this
vr6-gti
How Do I Remove Fog Light On 04 Rx330?
Hello all. I'm a new member. I have a 04 RX330 and I can't figure out how to remove the fog light to change the light bulb. Can someone send me info or a diagram that shows how it comes out? Do I have to remove the bumper or the wheel liner? Thanks in advance.
joey
Share this post
Link to post
On most newer Lexus models without visible screws holding in the bumper mounted fog lights, the standard way to replace a fog light bulb is to loosen the forward portion of the wheel well liner just enough to slip your hand in to remove the old bulb and insert a new one.
Share this post
Link to post
Thanks for the confirmation. I was thinking that was the way to do it but I thought maybe the light has a tension clip to easily slip it out but guess not.
Share this post
Link to post
Also, you don't need to remove the entire foglight "housing" to remove the bulb, just reach your arm behind it (through the wheel liner) and twist the bulb out of the housing.
Share this post
Link to post
Loading...
