Bank 1 P1133 Sensor
Cherri
Hello I have a 99 RX300 with 187,k miles my check engine light came on so I had it tested it gave me a Bank 1 P1133 code, can someone tell me what this means and can I replace this myself, if so where can i find the parts?
Thank you
Thank you
The attached document may be helpful in tracking down the problem. Good luck!
SFI (SF) file.pdf
Thank you
Joe- since the P1133 code (Lexus specific) says "Air/Fuel ratio sensor circuit response malfunction, bank1, sensor1", I was just curious why you referenced the file that you did?
