Part Number For Door Rod Clip 95 Es300
So i apologize because i know you all have seen threads on this subject many times. But i used the search function and couldnt find anything to help me. So my 95 es300 passenger door has the broken clip that connects the actuator rod to the outer door handle. I cant find anywhere the part number for that little clip. If somebody could help me out it would be much appreciated. Thank you
There aren't enough gear heads and wrenchers on this site for anyone to have that part number. Your best bet is to go to a Toyota or Lexus dealership, describe what you want, and let them do a computer search. They should have one or two in stock. Remember that the same year Camry should most likely use the same part. Good Luck!
