My 06 Lx470 Makes A Thunk Sound When Stopping Then Starting
pmclay
Sounds like the famous "Clunk" issue. Toyota actually issued a TSB (technical service bulletin) for it back in 2006, but then updated it in 2008. It basically involves the dealer replacing the drive shaft. Now I think there is a new propeller shaft assembly.
This was for the GX 470, but I am pretty sure other models like the LX, RX and a few others experience the same thing. People were saying that if you have less than 70K (?) the dealer does it for free.
For a temporary solution (if that is what this problem is), you can try greasing the drive shaft, a lot of people reported that the problem then goes away for 3K - 10K miles depending.
Here is a link showing the lube points.
http://www.4x4wire.com/toyota/maintenance/front_end/lube/
Look at the bottom of this page, there is a good explanation about possible Clunk causes.
I am attaching the TSB I found for the Clunk, & also another one about vibration.
CLUNK_TSB_2008.pdf
Steering_Drive_Line_Vibration_issue_Feb_2008.pdf
