Volcano29 Posted August 8, 2010 Posted August 8, 2010 First of all, Ive been researching to see if another person has had the same issue as me and I came up with this http://www.fixya.com/cars/t3493357-2001_lexus_rx300_problem_when This person has the exact same issue as me. However I would like to add a few things. The vibrating/nasty sound (It holds the car back for about 2-3 seconds and does not let it accelerate smoothly) only happens when accelerating from a stand still and when this occurs the traction signal lights up in my dash. Another thing I would like to add is that I went to a trip 2 weeks ago and I set the parking brake overnight. The next morning, the "problem/issue" occurred for about a minute and I had to forcefully by accelerating get the car to move. Then I heard sort of a whinning noise as I drove, but that went away after about a minute. It leads me to believe that something is sticking such as the parking brake. This is what the website above mentioned, "parking brake dragging". Does anyone have any ideas? Thanks P.S. This is driving me crazy as I have had this issue for about a year and its getting worse and worse...
carguy07 Posted August 9, 2010 Posted August 9, 2010 First of all, Ive been researching to see if another person has had the same issue as me and I came up with this http://www.fixya.com/cars/t3493357-2001_lexus_rx300_problem_when This person has the exact same issue as me. However I would like to add a few things. The vibrating/nasty sound (It holds the car back for about 2-3 seconds and does not let it accelerate smoothly) only happens when accelerating from a stand still and when this occurs the traction signal lights up in my dash. Another thing I would like to add is that I went to a trip 2 weeks ago and I set the parking brake overnight. The next morning, the "problem/issue" occurred for about a minute and I had to forcefully by accelerating get the car to move. Then I heard sort of a whinning noise as I drove, but that went away after about a minute. It leads me to believe that something is sticking such as the parking brake. This is what the website above mentioned, "parking brake dragging". Does anyone have any ideas? Thanks P.S. This is driving me crazy as I have had this issue for about a year and its getting worse and worse... This is an issue with the ABS system getting bad info from a sensor. You can start by cleaning the sensors and see if that makes it go away. It is very likely a cracked/broken reluctor ring. You can pull the relay for the ABS and it will stop kicking in, but of course you won't have ABS anymore. http://www.clublexus.com/forums/rx-first-generation/514345-diy-repair-broken-reluctor-ring-tone-ring.html
