Front End Noise
Hey guys,
I have a 99 GS300 and only when I hit some decent bumps there is a banging noise that comes from what seems to be the right front wheel. It's not hard banging, but you can hear it in the car. I pulled everything off, shook the car, pulled and pushed on everything and could not replicate the sound. Only when I drive and hit some decent bumps i can hear it. On normal bumps and dips you can't hear anything at all. I have a new upper control arm and replaced the hub bearing and it's still there. I went under the car and put a wrench on all the bolts i could and it's still there.
Before I go further, is there a common part that can cause this noise on these cars, or someplace I should focus on first? I appreciate any help I can get.
Manually pulling and pushing parts won't always provide for the necessary G's, as you state it only happens when you hit a decent bump.
There are some usual suspects to investigate:
- worn upper strut mount (perhaps need tightening)
- worn lower ball joint(s) and/or outer tie rods.
- 'loose' sway bar bolts
- worn engine and/or tranny mounts
Does the noise also occur when you hit a decent bump and brake?
Yeah, applying the brakes doesn't make it stop, so I counted out the caliper and bracket. I double checked the bolts anyway. I checked both uppper strut mounts and they were tight. Someone else mentioned the sway bar end links and bolts, so I will check that tomorrow. Think I might also just go ahead and replace the lower ball joint while I'm there.
I'll tell you what. I've had this problem since I first got my GS. I get mine when going in and out of a parking spot; basically it feels like when I apply the brakes that my pass side caliper it 'activating' before my driver side does. I've changed out:
- All brake pads
- Slide pins on the caliper
- Front sway bar bushings with daizen bushings
- Rear sway bar bushings with daizen bushings
- Front end bushings with daizen bushings
- Steering rack bushings with daizen bushings
- Brand new lower control arm #1's on each side with daizen bushings
- New rotors all around
- New upper front control arms
- New front outer toe control rods
- New front lower ball joint
- New inner tie rods
- New oem brake fit kits both front and rear
I can't even remember the rest but basically most of my parts are brand spanking new. I even have new parts in the rear. I changed out my suspension with full coilovers, etc.
I realized when I changed my brakes the noise went away for a bit then came back.
I've tightened all bolts to spec using lexus manuals, etc and still have the issue. I've read alot and some say its a floating caliper/braking system design and that the stock/oem pads are made to counteract this.
I'm going to check it one more time before I sell the car because its driving me insane.
