TonyP Posted February 9, 2004 Share Posted February 9, 2004 I have a 2000 GS300. The check engine light went on, and the engine began to run very rough, like one cylinder wasn't firing. The dealer said that the seal on a casting plug leaked coolant into one of the cylinders and shorted-out a spark plug. The dealer said that it was not a head gasket leak, but a plug used to fill one of the holes used to remove sand in the original casting process. He also said that he had never seen this happen before. Anyone out there heard of this one? Quote Link to comment Share on other sites More sharing options...
A1SUPERNOVA Posted February 10, 2004 Share Posted February 10, 2004 Casting plugs typically don't fail, but when they do they will do two things; dump your coolant fluid out from or into the valve head and or main block. It's not a major repair if the coolant did not cause other internal damage!!. If the plug is accesible, typically not, a competent machine shop should be able to evaluate it properly. When replacing these (plus) use only what Toyota recommends. I only use bronze, but then again my application is marine... A1SUPERNOVA Quote Link to comment Share on other sites More sharing options...
TonyP Posted February 11, 2004 Author Share Posted February 11, 2004 Thanks for the insight. The dealer repaired the leak under warrantry, and told me that the leak was at the intake manifold. Luckily, no damage done to the engine. Quote Link to comment Share on other sites More sharing options...
