jimgu1964 Posted July 20, 2010 Share Posted July 20, 2010 Fuses and such checked by my mechanic and are Ok. He says next step is to remove the seats according to repair manual. Any thoughts on what the problem might be and how costly to repair? Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted July 21, 2010 Share Posted July 21, 2010 What are "fuses and such"? Did your mechanic perform the seat heater diagnostic routine described in the repair manual set for your car? The routine involves testing each component of the seat heater system by testing pins on switches and connectors for resistance, continuity, voltage, etc. It is a foolproof procedure that removes the guesswork and will tell you exactly what is wrong -- should take a competent mechanic less than one hour to perform. Quote Link to comment Share on other sites More sharing options...
jimgu1964 Posted July 21, 2010 Author Share Posted July 21, 2010 What are "fuses and such"? Did your mechanic perform the seat heater diagnostic routine described in the repair manual set for your car? The routine involves testing each component of the seat heater system by testing pins on switches and connectors for resistance, continuity, voltage, etc. It is a foolproof procedure that removes the guesswork and will tell you exactly what is wrong -- should take a competent mechanic less than one hour to perform. Quote Link to comment Share on other sites More sharing options...
jimgu1964 Posted July 21, 2010 Author Share Posted July 21, 2010 I don't know but I will sure find out! Thanks, Jim Quote Link to comment Share on other sites More sharing options...
