Fuses and such checked by my mechanic and are Ok. He says next step is to remove the seats according to repair manual. Any thoughts on what the problem might be and how costly to repair?
What are "fuses and such"? Did your mechanic perform the seat heater diagnostic routine described in the repair manual set for your car? The routine involves testing each component of the seat heater system by testing pins on switches and connectors for resistance, continuity, voltage, etc. It is a foolproof procedure that removes the guesswork and will tell you exactly what is wrong -- should take a competent mechanic less than one hour to perform.
