Rx400H Battery Replacement Cost
I am looking into buying a pre-certified Lexus 2007 RX400h SUV with about 29k miles. I know the battery warranty is far from being expired, but would still like to know how much a replacement battery would cost. On the internet, I'm only find costs of about $3k, but that was in 2008. It's now 2010 and wondering if the cost has gone down. Any info is appreciated. Thanks.
I wouldn't worry about it. There are lots of older Priuses on the road without battery problems. Did you look for used batteries on eBay? You can save a lot buying one from a newer wrecked car. Looks like it's the same as the Highlander Hybrid battery.
http://cgi.ebay.com/ebaymotors/BATTERY-TOYOTA-HIGHLANDER-LEXUS-RX400-06-07-HYBRID-_W0QQcmdZViewItemQQhashZitem20af76032bQQitemZ140382700331QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
http://cgi.ebay.com/ebaymotors/06-07-Lexus-RX330-Hybrid-Highlander-Hybrid-Battery-OEM-_W0QQcmdZViewItemQQhashZitem2eadf3b5beQQitemZ200486925758QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
p.s. you might want to clarify the title of the post to "hybrid" or "traction"
battery, since at first it appears you mean the 12V auxiliary battery.
Out of all the hybrids on the road, there has yet to be one with depleted batteries, and that includes Prius versions with over 250,000 miles on them. Unless you plan to drive 50,000 miles per year, you really don't have to worry about having to replace the traction batteries.
Regarding reliability: Our RX400h is now more than 5 years old with more than 50,000 miles on it and we have not had one problem. That in of itself is truly amazing and a good sign of future reliability.
Thanks all for the re-assurance and replacement cost of the "traction" battery on the RX400h. I'm a hybrid car newbie so still learning the terminology. :)
I purchased a preowned 2006 Rx400h with about 40k on the odometer and did a bunch of research on the batteries before I made the move to purchasing the vehicle. Basically I found out that Lexus warranties the drive batteries for 100K miles but even then, unless something radical happens you can replace the individual cells without having to replace the entire battery bank. If I remember correctly the vehicle has 25 or 28 Lithium Ion cells that make up the battery bank, and they can be replaced individually if needed.
From all my information gathering I think it is very rare to have to replace the entire battery bank and like many poeple on the forum have relayed there are vehicles with 200K+ that have never had an issue with batteries.
The one thing you will worry about, is the actual "traditional" battery that turns on the electronics which will get the computers and the "traction" battery under way.
The factory "skinny" battery you will find under the engine bay is a P.O.S.
I do not know how many times in the 4 years of ownership, that battery has been depleted. Sometimes, I am away on business for a week or more, and my wife likes to take my car and leave the 400h in the garage. And, sure as chit, the bugger is too low to power up the computers.
Some on the boards have invested in "trickle" chargers, to maintain the "starter" battery for the computers, but to be perfectly honest this is not practical for most. I do not expect my wife to unplug the plastic shroud housing covering the "starter" battery and have her plug in the maintenance charger. Then, when she wants to go out, remove it and fiddle with the plastic plugs that hold the plastic housing in place.
Finally, after 50 months of use, and after several complaints to the dealer service department over the life of the vehicle (they never changed it or said there was a problem), the factory battery was diagnosed at 25% capacity yesterday and was deemed to be replaced. 2 months out of warranty. Nice, eh? Well the dealer wanted $250 for an oem battery and offered a 1 year warranty. I said thanks but no thanks, and went to a popular auto parts store in my neck of the woods and spent $120 for a battery that came with a 3 year replacement warranty (with an additional 6 years prorated warranty). As well, at time of purchase, if you take there $9.99 insurance plan, the 6 years prorated becomes 6 years replacement at no additional charge.
I couldn't justify the cost of going the "Optima" spiral wound battery route, given the exorbitant cost and very marginal warranty.
Food for thought, make sure the engine battery is in good shape (it has been the only part failure so far on my RX 400h).
Cheers,
MadloR
Cheers,
MadloR
Agreed! My RX400h (auxillary) battery died [one dead cell] under warranty (luckily) and the car was towed to the dealer and replaced at Lexus' cost. The battery tends to deplete easily if the car is not used for a few days. I believe the manual documents that the car be driven for few (?) miles every 2 days. I believe that the (aux.) battery is only charged when the gasoline motor is running. Since the gasoline motor is not engaged at all times, maybe the battery is not charged the same way it is done in a conventional gasoline vehicle. But my understanding maybe flawed about this. But in any case, Lexus should have designed this better and reliably.
Regarding starting batteries: According to Consumer Reports magazine, the best battery out there is the Sears Platinum. Unfortunately, it costs $180 + tax. While our RX's battery is now over 5 years old, when it comes time to replace it, I will look into a Costco Kirkland battery (about $60) to see if its reserve capacity is beyond what the OEM battery has to offer.
Does anyone know if one of those solar chargers plugged into one of the 12 volt outlets would charge the starter battery? I have one on my boat and it keeps the two batteries there topped up nicely. Of course I wouldn’t be surprised if there were some relay that prevented it from working. They're pretty inexpensive, I think mine only cost about $20.
I am not sure, but I think that there is probably a diode inline, therefore limiting the "travel" of electricity between the battery and the lighter plug. The way to be sure is, with a voltmeter. Put the voltmeter on the battery and register the voltage, then, plug in the solar charger or whatever type of maintenance charger you have and record the voltage reading at the battery to see if there is any significant increase. A digital type voltmeter would be the type you would need, since it would be easier to detect any type of change (vs a conventional analog voltmeter).
Cheers,
MadloR
i am happy with the $60 costco replacement battery, it has slightly more cold cranking power and can handle a dome light left on all night and still start the car in the morning. costco also has a 3 year warranty that is not prorated, so if the battery fails in the warranty period you get a new one at no additional cost. i am not married to them for everything, i.e. tires, however i think they are hard to beat on batteries.
Another thing to note is, the replacement battery that Lexus provided under warranty is slightly bigger than the original one. Thus it does not sit within the battery tray, rather it sits on top of the flange of the tray. I noticed this and clarified it with the mechanic at the dealer. He said that's how the newer batteries are, but the clamp will hold it in place. Not to mention, the new battery has not moved from the tray in 8 months. But it still seems awkward that the replacement battery has a different footprint than the factory battery. The battery problem I beleive is not uncommon. My car would not turn "Ready" and would indicate "Shift to P when starting" even though it was already in "P"! I had to take a picture and show the dealer as they were not able to reproduce it. If left for long, the battery would most times work. Lexus dealer couldnt diagnose the problem, kept my car for 1 week (and offered me a standby vehicle which I declined) but couldn't figure the cause. Then I suggested them to perform a load test on the battery and they found out the "weakened/dead" cell. Touch wood its been working since.
The auxiliary battery (12 volt) is charged from the traction battery. There is no alternator, so the engine does not have to be running to charge the 12 volt. As long as it's in READY mode, the 12 volt will charge from the traction battery. It's not a matter of being designed better, I think the 12 volt is just too small (not in physical size, but in reserve capacity) for this vehicle. The CCA (cold cranking amps) do not matter, since there is no starter motor on our vehicles, however, usually with greater CCA comes greater reserve capacity. The factory battery only came with 450CCA, which is about perfect for a 4 cylinder Civic.
Does the traction battery start the engine or does the 12V aux battery do this? The reason I ask is that if it's the traction battery starting the engine and the aux battery just runs the electronics, maybe a deep cycle battery with a higher reserve capacity would do a better job than a start battery.
A motor generator (termed MG1) recharges the traction battery, controls the variable transmission through a planetary (Epicyclic) gear set and and also starts the engine. A simple answer to your question, the traction battery starts the engine.
Jim, Yep, I had to replace my start up battery at 43K. I've found a solution for the trickle charger problem. Go to your local Harley dealer and buy their electronic battery maintainer for $50. It has a pigtail you can attach permanently to the battery posts and then you can plug the charger into the pigtail when needed without having to remove the battery cover. This charger detects the battery voltage and will charge at 2 amps until the battery reaches full charge. Then it shuts off and goes to standby and waits for the battery voltage to drop and then it turns on and recharges. This electronic charger is perfectly safe for electronics as it was designed for the new Harleys with electronic ignitions and fuel injection. Works like a charm.
Regards,
Luke :cheers:
Cheers,
MadloR
I believe that not all battery "tenders" are also chargers. One of the most popular charger/tenders is the Deltran Battery Tender Plus. It will charge a weak battery until fully charged and then just "tend" by keeping the battery at that charge level.
However, some AGM batteries, if depleted to a certain level, require more than the 1.25-2 amps that tender/chargers can supply. 8-10 amps is recommended for some of those types of batteries.
  • 6 years later...
hi all
i live in san jose, ca, i called stevens creek lexus, and they said to replace the bank of traction batteries is $6500 plus labor
after getting over the sticker shock, doing further research, i havent heard of anyone replacing them.
my 2006 RX400H has about 190K miles
i am going to get another SUV soon, probably a new RX350 or something in that size range
z
Regards,
Luke :cheers:
hi all
if you can remove the engine shrouds, and take out the 12v battery, go to costco or an auto parts store and get a replacement.
if you cant do that, go to a competent mechanic,or if you go to the dealer, you pay the $$$
if you do it yourself, you do have to reset the rear windows via the instructions in the manual
i think its a common issue on most new cars, my infiniti made me go thru the same "song and dance" to get the power windows to work properly
z
  • 2 months later...
Had an '06 RX400h and never any problem with either the 12V battery or main battery. It was, unfortunately, totalled in a wreck at 145K and still going strong. Never a problem of any kind.
We replaced with a '13 RX450h, and with around 121K, still no problem with either battery on it, either.
Yeah, we are "road runners" :)
Thanks for all the great info, though, I'll be prepared if ever needed!
