"Lexappeal" Posted February 7, 2004 Share Posted February 7, 2004 Guys and ladies, any advice on a set of 19x8.5" and 19x10" HRE fully polished with the aluminum center cap instead of plastic, full 3 piece wheels with Yokohama 245/35/19's up front and 275/30/19's in the rear. Also looking at the Tein Flex coilovers and AP racing big brake kit. It has 14" front cross-drilled and slotted rotors and 6piston calipers. Stainless steel lines all the way around and oem drilled and slotted rear rotors. Please any imput is much appreciated!!! Thanks Quote Link to comment Share on other sites More sharing options...
TWINTURBO619 Posted February 9, 2004 Share Posted February 9, 2004 Guys and ladies, any advice on a set of 19x8.5" and 19x10" HRE fully polished with the aluminum center cap instead of plastic, full 3 piece wheels with Yokohama 245/35/19's up front and 275/30/19's in the rear.Also looking at the Tein Flex coilovers and AP racing big brake kit. It has 14" front cross-drilled and slotted rotors and 6piston calipers. Stainless steel lines all the way around and oem drilled and slotted rear rotors. Please any imput is much appreciated!!! Thanks it sounds all good. is your car lowered or already lowered? Quote Link to comment Share on other sites More sharing options...
"Lexappeal" Posted February 9, 2004 Author Share Posted February 9, 2004 No the car is stock height, do I need to lower it as well as put the coilovers on? Quote Link to comment Share on other sites More sharing options...
"Lexappeal" Posted February 9, 2004 Author Share Posted February 9, 2004 Anybody out there with the Tein Flex- and do you like it or would you recommend the Tein CS. Thanks for your input Quote Link to comment Share on other sites More sharing options...
r00kie Posted February 10, 2004 Share Posted February 10, 2004 No the car is stock height, do I need to lower it as well as put the coilovers on? The coilovers will lower it when you put it in. You will be able to adjust the height also with the coilovers. Quote Link to comment Share on other sites More sharing options...
r00kie Posted February 10, 2004 Share Posted February 10, 2004 Anybody out there with the Tein Flex- and do you like it or would you recommend the Tein CS.Thanks for your input I don't have either, but figure I can let you know what I've read until someone who has these installed can chime in. Basically, the Tein CS will give a softer, more stock ride and the Flex handles better, but the ride will be rougher. Quote Link to comment Share on other sites More sharing options...
Neo Posted February 10, 2004 Share Posted February 10, 2004 Anybody out there with the Tein Flex- and do you like it or would you recommend the Tein CS.Thanks for your input What kind of ride are you looking for? I've had both and I liked both. It just depends on your ride goal. Quote Link to comment Share on other sites More sharing options...
MrSypher Posted February 10, 2004 Share Posted February 10, 2004 I have the Flex and I've loved them since I saw them sitting in the box.. They are great coilovers, the ride and feel is great considering they're coilovers.. IMO I don't think there's any need to go with the CS because with 20's and the flex there isn't anything harsh about my ride.. And as for handling, my GS rides like it's on rails.. But I also have alot of other suspension mods too.. Everything you mentioned that you want are great choices and you'll be happy with each thing.. If you want I can get everything you want, and since your a member here I'll give an extra discount... Quote Link to comment Share on other sites More sharing options...
"Lexappeal" Posted February 11, 2004 Author Share Posted February 11, 2004 Hey Mr. Sypher if you could pm me a price for everything!! Appreciate it bud... Also thanks to all for your input, I think I will go with the Tein Flex kit!!! Quote Link to comment Share on other sites More sharing options...
MrSypher Posted February 11, 2004 Share Posted February 11, 2004 Okay.. No problem.. Quote Link to comment Share on other sites More sharing options...
HREWheelMaker Posted February 17, 2004 Share Posted February 17, 2004 For the wheels, you could try Peter@wheelexperts.com Quote Link to comment Share on other sites More sharing options...
