viktorpet Posted June 10, 2010 Share Posted June 10, 2010 I've problems with my 01 300gs. It was sitting for 2 weeks, when I started it, seatbelt light was on, even I was buckled-up, then temp. gage went down, then dash board (speedometr, tachometer) started on and off, airbag light on, finnaly, when I get back home, alarm turned on. Does anybody know, what is going on with it?!?!?! Quote Link to comment Share on other sites More sharing options...
dcfish Posted June 10, 2010 Share Posted June 10, 2010 Try disconnecting the neg battery terminal for a few minutes , Then reconnect. Post results please Quote Link to comment Share on other sites More sharing options...
viktorpet Posted June 11, 2010 Author Share Posted June 11, 2010 Try disconnecting the neg battery terminal for a few minutes , Then reconnect. Post results please Didn't work, started oil light on/off, battery light on/off. It scares me. Power lock doesn't work, opens rear left door only, and trunk, power windows do not work from driver door. Please help!!! Thank you!!! Quote Link to comment Share on other sites More sharing options...
dcfish Posted June 11, 2010 Share Posted June 11, 2010 Try charging the battery or have your battery tested for proper output. Could be your alternator is going bad. Quote Link to comment Share on other sites More sharing options...
intakerGS Posted June 11, 2010 Share Posted June 11, 2010 It seems some electrical parts don't get their minimum threshold voltage. You need to rule out the usual culprit; check battery current (12+V) without cabling, clean battery poles, check for corroded (ground) wiring or harness, switching relay's etc. (dcfish was a bit faster) A long shot: if you have an (aftermarket) alarm installed, you need to check the small emergency-battery (and/or disconnect alarm if possible). Emergency battery's have a limited lifespan. They can drain or short-circuit your car's battery and/or electrical circuit, causing all kinds of mysterious electrical-, startup- and alarmproblems. Quote Link to comment Share on other sites More sharing options...
viktorpet Posted June 11, 2010 Author Share Posted June 11, 2010 It seems some electrical parts don't get their minimum threshold voltage. You need to rule out the usual culprit; check battery current (12+V) without cabling, clean battery poles, check for corroded (ground) wiring or harness, switching relay's etc. (dcfish was a bit faster) A long shot: if you have an (aftermarket) alarm installed, you need to check the small emergency-battery (and/or disconnect alarm if possible). Emergency battery's have a limited lifespan. They can drain or short-circuit your car's battery and/or electrical circuit, causing all kinds of mysterious electrical-, startup- and alarmproblems. No, I have manufactured alarm... :cries: Quote Link to comment Share on other sites More sharing options...
dcfish Posted June 11, 2010 Share Posted June 11, 2010 With the car running, Measure the voltage coming out of the alternator. Should be between 14 and 15 (the exact voltage escapes me ) Quote Link to comment Share on other sites More sharing options...
intakerGS Posted June 11, 2010 Share Posted June 11, 2010 Most alarms carry a seperate backup-battery. Mine was installed by lexus and after 10 years it was EOL, draining the car-battery completely and creating all kinds of electrical- and starting problems. After ruining 2 fresh batteries, it came to mind :cries: . In case the other options lead to no solution, you can easily check if something is draining your battery. With the car running, Measure the voltage coming out of the alternator. Should be between 14 and 15 (the exact voltage escapes me ) Don't forget to enable electrical devices too, like AC/wipers/lights/radio/heated windows etc. You may have to revv a little around 1200 RPM. Quote Link to comment Share on other sites More sharing options...
viktorpet Posted June 14, 2010 Author Share Posted June 14, 2010 Try disconnecting the neg battery terminal for a few minutes , Then reconnect. Post results please Disconected for overnight, looks like all work now!!! Quote Link to comment Share on other sites More sharing options...
dcfish Posted June 14, 2010 Share Posted June 14, 2010 Try disconnecting the neg battery terminal for a few minutes , Then reconnect. Post results please Disconected for overnight, looks like all work now!!! Quote Link to comment Share on other sites More sharing options...
