Luis Arnel Posted May 26, 2010 Share Posted May 26, 2010 Hi again guys! My GS have a problem that both panel and shifter base indicator don't synchronize with the shiffter position. Example, when I place shift in "2", the "D" light came on (is the only time panel indicator works). Is there a sensor malfuntion? which one is to order it? Thanks again! Luis Quote Link to comment Share on other sites More sharing options...
GuyTelefunken Posted May 27, 2010 Share Posted May 27, 2010 It's called the Neutral Safety Switch. It's on the side of the transmission above the exhaust. It's somewhat difficult to get at. It is possible that the shifter linkage to it has loosened but more likely that it is failing. p/n 84540-30270, about $110.00 retail if you look for the (Toyota) part number given. Note that this switch, if bad can cause the car to not start or start with the shifter in a position other than "P" or "N", which can be dangerous. Quote Link to comment Share on other sites More sharing options...
