GSspeed Posted February 5, 2004 Share Posted February 5, 2004 okay only on my passenger side im getting condensation in the main head light and in the highbean headlight, does any one else have this problem and what is the solution other than buying a whole new housing, Quote Link to comment Share on other sites More sharing options...
Neo Posted February 5, 2004 Share Posted February 5, 2004 Seems like a common problem. If you are still within warranty, run don't walk to the dealer and get it replaced. If the warranty is over, I've heard of some successes with Lexus Customer Satisfaction and potentially escallating to Lexus Corp Pres. There is some persistence and hard work involved going down that path though. Otherwise, buy another one like you said or live with it. Quote Link to comment Share on other sites More sharing options...
TWINTURBO619 Posted February 5, 2004 Share Posted February 5, 2004 okay only on my passenger side im getting condensation in the main head light and in the highbean headlight, does any one else have this problem and what is the solution other than buying a whole new housing, I BELIEVE THE PROBLEM IS WITH THE BREATHER THAT HANG BEHIND THE HOUSING OF THE LIGHT. SEE IF YOU CAN TAKE THEM OFF AND CLEAN THEM OFF. THAT SHOULD HELP. GOOD LUCK. Quote Link to comment Share on other sites More sharing options...
gs3ee Posted February 11, 2004 Share Posted February 11, 2004 turbo619 is probably right if not you can always seal it yourself with black silicone Quote Link to comment Share on other sites More sharing options...
