STORMINORMAN Posted May 10, 2010 Share Posted May 10, 2010 Anyone had any luck in getting the condensation to stop/out of taillight lenses? Mine look fine, no cracks, damage or otherwise unusual: just beads of water inside on both sides. Is there a fix? Drilling drain holes with a Dremmel? Any hints on how to remove/replace other than "...just have the Dealer put in new one$"? Quote Link to comment Share on other sites More sharing options...
polarbreeze Posted May 28, 2010 Share Posted May 28, 2010 I had the same problem and I found that drilling drain holes worked OK for a while but eventually they fog up on the inside. You have to be very careful where you drill the holes: note that the lens has a kind of double skin and the condensation accumulates between the two layers. That's where the hole needs to go to. Once I'd drilled the holes I blew air through them with a hairdryer (make a kind of a funnel thing with a drinking straw to blow through the hole). Also, I've never tried it but maybe you could put some dessicant in there to soak up excess moisture It's only a temporary fix though. Put a search out on eBay for replacements. Anyone had any luck in getting the condensation to stop/out of taillight lenses? Mine look fine, no cracks, damage or otherwise unusual: just beads of water inside on both sides. Is there a fix? Drilling drain holes with a Dremmel? Any hints on how to remove/replace other than "...just have the Dealer put in new one$"? Quote Link to comment Share on other sites More sharing options...
STORMINORMAN Posted June 11, 2010 Author Share Posted June 11, 2010 polarbreeze: Thanks for your reply: obviously the drain holes should go "on the bottom" of the lens (DUH!), but where did you allign them laterally? More than one per side? Penetrate outer layer only? 1/4" deep? Thanks again! You are the only one on three forums to bother to respond... Norm I had the same problem and I found that drilling drain holes worked OK for a while but eventually they fog up on the inside. You have to be very careful where you drill the holes: note that the lens has a kind of double skin and the condensation accumulates between the two layers. That's where the hole needs to go to. Once I'd drilled the holes I blew air through them with a hairdryer (make a kind of a funnel thing with a drinking straw to blow through the hole). Also, I've never tried it but maybe you could put some dessicant in there to soak up excess moisture It's only a temporary fix though. Put a search out on eBay for replacements. Anyone had any luck in getting the condensation to stop/out of taillight lenses? Mine look fine, no cracks, damage or otherwise unusual: just beads of water inside on both sides. Is there a fix? Drilling drain holes with a Dremmel? Any hints on how to remove/replace other than "...just have the Dealer put in new one$"? Quote Link to comment Share on other sites More sharing options...
