josephvman Posted February 4, 2004 Share Posted February 4, 2004 I recently bought a 1-owner (my mother was trading it for a new BMW 5, and I needed a cheap beater car) '94 ES300 w/ 99k. The a/c doesn't seem to work in very hot weather, and there is definitely some sort of "moaning" sound coming from the engine compartment with the a/c on. It does seem to cool okay in moderately warm weather, but still makes noise. I'm guessing it may need a new compressor, or maybe I'll get lucky and it may be a belt. The car had a timing belt service just before I got it, and I'm assuming they would have replaced all the accessory belts at the same time, but I'm not positive. The one thing I've noticed that's strange is that when I put the climate control in AUTO (pushing the big temp dial), the a/c goes on, no matter how cold the ambient temp, or what temp I have the AUTO set to. Is this normal? The remote trunk release seems to have stopped working all of a sudden. Can anyone point me in the right direction to repair it? The heated seat switches light up, but the seats don't get warm. Occasionally I will feel very little heat. This sounds more like the heating wires in the seat than the switch, but any suggestions? Thanks! Joe in Houston Quote Link to comment Share on other sites More sharing options...
SKperformance Posted February 4, 2004 Share Posted February 4, 2004 If it is a cheap beater who cares if the heated seats and a/c work? Quote Link to comment Share on other sites More sharing options...
blake918 Posted February 4, 2004 Share Posted February 4, 2004 Welcome to the club Joe :D ! About the trunk...is the switch on in the glovebox? This a common problem for many people when they first get their ES. When it's cold outside and you have the heat on, the climate control will wait for the engine temp to get to a decent temperature so that it doesn't blast you with cold air when it's 40deg. outside. You can see if the climate control computer is detecting any problems by holding recirculate and auto, and then turn the key at while holding those buttons. The climate control will flash and beep and show you a code if any. It should not blow out cold air all of the time especially if you have it set on heat! I have no clue about the seats :( . Quote Link to comment Share on other sites More sharing options...
amf1932 Posted February 4, 2004 Share Posted February 4, 2004 The one thing I've noticed that's strange is that when I put the climate control in AUTO (pushing the big temp dial), the a/c goes on, no matter how cold the ambient temp, or what temp I have the AUTO set to. Is this normal? Yes, this is normal. Quote Link to comment Share on other sites More sharing options...
dropspace Posted February 5, 2004 Share Posted February 5, 2004 does it run the ac compressor in cold weather? or does AUTO just make the light come on? i always shut off the a/c because i dont want the thing running all the time when its not needed.... Quote Link to comment Share on other sites More sharing options...
amf1932 Posted February 5, 2004 Share Posted February 5, 2004 The AUTO position will make the AC compressor light come on. This will happen whether the compressor is operating or not. Below a certain temperature the compressor will NOT come on, even though the light is lit. Quote Link to comment Share on other sites More sharing options...
