cm786 Posted May 5, 2010 Share Posted May 5, 2010 While using synthetic oil, how often (miles) do you change oil in a 2008 LS460? Quote Link to comment Share on other sites More sharing options...
SW03ES Posted May 6, 2010 Share Posted May 6, 2010 Doesn't Lexus specify 10,000 miles now with synthetic oil? Do you have the factory maintenance schedule? Quote Link to comment Share on other sites More sharing options...
HH The Bahbi Lama Posted May 6, 2010 Share Posted May 6, 2010 My 2009 LS requires a change every 5K Quote Link to comment Share on other sites More sharing options...
SW03ES Posted May 7, 2010 Share Posted May 7, 2010 It may only be the 2010 then... Quote Link to comment Share on other sites More sharing options...
limocad Posted May 18, 2010 Share Posted May 18, 2010 It may only be the 2010 then... No. The 2010 requires oil change at 5K too and it uses 0W20 which is 100% synthetic. After 10K miles I switched to 5W20, Mobil 1. The car is running smoother and quieter with 5W20. Quote Link to comment Share on other sites More sharing options...
lex460 Posted May 18, 2010 Share Posted May 18, 2010 It may only be the 2010 then... No. The 2010 requires oil change at 5K too and it uses 0W20 which is 100% synthetic. After 10K miles I switched to 5W20, Mobil 1. The car is running smoother and quieter with 5W20. I noticed the same thing less chain noise with Mobil 1 5-20w full syn over the Toyota red. Quote Link to comment Share on other sites More sharing options...
