What Size Wrench?
stroker
I'm trying to get the air control valve off of the P/S pump and it seems like its an 11/16 but not sure; also normal wrench gives no room to loosen or tighten.. I plugged both lines going to the engine and even with the spring clips on the hoses, when you run the engine I guess the pressure pops off one of the lines at the valve.. Any help would be appreciated, Thanks, Bobby
Ah ha, you are in luck because I happened to have one in my toolbox so I just went out to the garage and measured up. You need a 17mm for this valve. By the way, I got this one off a Camry at a junkyard, they are the same. I will go over to Fastenall when I get a chance and pick up a bolt with the same threads, some locktite and close it up.
I finally found a 17mm wrench (had to buy a set of stubbies). They are about 5 inches long so I should be able to get in there to take the old valve out. What a dirty job! Also picked up a bolt and am going to just seal it up for good I hope. I just want to thank you for the info and am glad to see that there are more people like yourself on this forum...Thanks again, Bobby
