400H Drivetrain Differences.
Long time RX300 owner looking to upgrade to a 2007/8 RH400H. What is the easiest way to tell the diff inbetween the FWD and AWD versions of the RX400H?
Sorry for the newbie question. I tried to search
Look under the back, between the back wheels. You'll see the MGR (Motor Generator Rear), which is Lexus's fancy name for the rear electric powered differential. You'll notice the cooling fins on the diff, and if you look closely enough, you'll see the drive shafts running to each wheel.
I figured I could always look under the car for the motor/axles and I could look at the navi for the rear motor indicator.
I was just wondering if there were any instrumentation diff with the auto selector or etc?
But thanks for the replies.
