Replace High Mounted Stoplight - 1998 Es300
meadow
How too replace high mounted stoplight - 1998 ES300
1. Slide the cover straight forward (toward you) to release the latches - they are two latches at rear of the cover); I used two screwdrivers, one at each side, to pull the cover forward out.
2. Lift cover up
3. Twist out (counter clockwise) bulb socket - same bulb type as tail stoplight
4. Push the socket back in - align one larger slot to push the socket back in
There haven't been too many recent posts on 98 ES problems. I noticed yours on the high-mounted stoplight and I wanted to see if you have experienced problems with hestitation and jerkiness at 40-45 mph while at cruise speed (not acelerating or decelerating). This started on mine at about 210,000 miles. I have 217,000 on it now. My mechanic said he can't find the reason. There were no codes and no lights. Any thoughts?
