LukeTushim Posted April 16, 2010 Share Posted April 16, 2010 How do you remove the lid to the center console on a 2002 GS300. Quote Link to comment Share on other sites More sharing options...
AliJaGS430 Posted April 25, 2010 Share Posted April 25, 2010 How do you remove the lid to the center console on a 2002 GS300. No sure but where did you find one? I need to replace mine. Quote Link to comment Share on other sites More sharing options...
chedir Posted May 1, 2010 Share Posted May 1, 2010 1) Lift up the lid and look underneath. You will see about 7-8 little screws- you will need a standard Philips screw driver 2) Unscrew them and them you the plastic underneath of the lid will come off 3) Next you will see 4 screws at the base near the hinge that still hold the lid. Unscrew the 4 using same Philips screw driver. You should be able to remove the console leather covered armrest. I had to this recently to replace the center console armrest- due to my sweaty arms over years, the leather ripped and hence I had to replace it. 1 Quote Link to comment Share on other sites More sharing options...
72dawg Posted May 13, 2010 Share Posted May 13, 2010 No sure but where did you find one? I need to replace mine. Just orderd on on Ebay. Quote Link to comment Share on other sites More sharing options...
LukeTushim Posted June 10, 2010 Author Share Posted June 10, 2010 That's awesome, thanks..I found a replacement cover on ebay for $40.00...much better to re-cover than spend $500 on a new lid..ridiculous. Appreciate it Luke 1) Lift up the lid and look underneath. You will see about 7-8 little screws- you will need a standard Philips screw driver 2) Unscrew them and them you the plastic underneath of the lid will come off 3) Next you will see 4 screws at the base near the hinge that still hold the lid. Unscrew the 4 using same Philips screw driver. You should be able to remove the console leather covered armrest. I had to this recently to replace the center console armrest- due to my sweaty arms over years, the leather ripped and hence I had to replace it. Quote Link to comment Share on other sites More sharing options...
