98 Es 300 Mpg
i would say it is just becaue of the cold. now that it is warming up i think u will see it go back.
two reasons why it gets bad in the winter
Weaker gasoline
Gasoline doesn't vaporize readily at very cold temperatures. So oil companies formulate fuel differently for cold-weather markets in the winter. Unfortunately, the changes that provide better cold vaporization characteristics also result in less available energy for combustion. You won't get as far on a gal of winter gas as you will on a gal of summer gas.
Temp
Have a gander at these calculations for a Honda Civic hybrid at 60 MPH in varying ambient temperatures:
MPH-----AMBIENT-TEMP-----MPG (US)
60------------95----------52.98
60------------85----------52.62
60------------75----------51.16
60------------65----------49.12
60------------55----------47.22
60------------45----------44.67
60------------35----------43.05
60------------25----------41.54
60------------15----------39.41
60------------05----------38.09
Look at the extremes: the coldest MPG is 28% lower than the warmest.
Weaker gasoline
Temp
ah i see. I would think since the air is colder it is denser, kinda like a cold air intake improving mpg or a turbo with an inter-cooler. never thought about the gas additives.
thanks for the input, ever tried a K&N filter?
