markcheck Posted April 11, 2010 Share Posted April 11, 2010 New user, hope this isn't a repeat but tried to search and could not find this: How do I add coolant to 2005 ls430? It seems to be in the very front center of engine bay but is covered by a small plastic cover (about 1-2 feet wide by 8 inches if I remember). Tried removing the screw (one of two) and lifting but I found it took some kind of screw-holder out of a hole that would not then go back in -- the bottom expanded as if it were designed to be removed and never go back in, and I had to squeeze separate pieces on the botttom of this screw-holder to try to get it back in the hole before I could put the screw back. The manual says to add coolant when needed but I cannot even figure out how to get the the overflow tank, which for the diagram appears to be under this cover. Also how can I find out what tool I need to remove main engine cover? I have always changed my own air filter but the manual doesn't even say how... I see two center bolts (not screws exactly) but don't know what kind of tool is needed to loosen or otherwise remove them. Thanks! Quote Link to comment Share on other sites More sharing options...
