yustle Posted April 10, 2010 Share Posted April 10, 2010 Someone stole one of my valve caps and I haven't been able to find a replacement online that is the same as the other three. Does anyone know where I can get one for the 2008 RX 350? I took a photo of one of the caps below. Quote Link to comment Share on other sites More sharing options...
scottq60 Posted April 10, 2010 Share Posted April 10, 2010 I'm pretty sure you can get a complete set of 4 practically identical to that one at Advance or any other parts store...maybe even Walmart. That's a pretty common design. The whole set would probably cost $5 or less. I think those may even be aluminum...here's a set of 6 on Amazon for $2.89 - http://www.amazon.com/Camco-44953-Valve-Stem-End/dp/B000T8E09U/ref=sr_1_1?ie=UTF8&s=automotive&qid=1270943848&sr=1-1 Quote Link to comment Share on other sites More sharing options...
apman Posted October 24, 2010 Share Posted October 24, 2010 You can buy caps from Toyota or Lexus dealers for $3+ per unit or buy Veesun aluminum caps(green or gold anodized) from Amazon. Use cleaner called Greased Lighting to remove the anodized color. Now you have 4 perfectly matched aluminum caps. Quote Link to comment Share on other sites More sharing options...
rx350guy Posted October 30, 2010 Share Posted October 30, 2010 I'm pretty sure you can get a complete set of 4 practically identical to that one at Advance or any other parts store...maybe even Walmart. That's a pretty common design. The whole set would probably cost $5 or less. I think those may even be aluminum...here's a set of 6 on Amazon for $2.89 - http://www.amazon.co...70943848&sr=1-1 Those aren't exactly the same as the factory caps, but pretty close. Probably the only way to get the exact same caps is from the dealer.. Quote Link to comment Share on other sites More sharing options...
