Tire Pressure Stem Valve Cap Replacement?
Someone stole one of my valve caps and I haven't been able to find a replacement online that is the same as the other three. Does anyone know where I can get one for the 2008 RX 350? I took a photo of one of the caps below.
I'm pretty sure you can get a complete set of 4 practically identical to that one at Advance or any other parts store...maybe even Walmart. That's a pretty common design. The whole set would probably cost $5 or less.
I think those may even be aluminum...here's a set of 6 on Amazon for $2.89 -
http://www.amazon.com/Camco-44953-Valve-Stem-End/dp/B000T8E09U/ref=sr_1_1?ie=UTF8&s=automotive&qid=1270943848&sr=1-1
  • 6 months later...
You can buy caps from Toyota or Lexus dealers for $3+ per unit
or buy Veesun aluminum caps(green or gold anodized) from Amazon.
Use cleaner called Greased Lighting to remove the anodized color.
Now you have 4 perfectly matched aluminum caps.
http://www.amazon.co...70943848&sr=1-1
Those aren't exactly the same as the factory caps, but pretty close. Probably the only way to get the exact same caps is from the dealer..
