TomGuzek Posted April 7, 2010 Share Posted April 7, 2010 At 90K miles my lx470's check engine light turned on, soon after the vsc lights turned on along with the abs. I had codes run and the o2 sensors needed replacement, had that done the problem disappeared but returned after a month. The dashboard reverse light turns on every time the brake is engaged and the mirrors adjust for reverse while the car is in Drive and moving forward if the the brakes are tapped. Is this a common problem, until today the car was, it still is mechanically fine but is there a remedy for this? Quote Link to comment Share on other sites More sharing options...
