1993 Ls400
GeoG
If you want the cheap way out, you need to replace three capacitors(C212, C142, C147) on the big and little board after you pull everything out of your dash. Take it to an electronics shop and they can replace the capacitors. Cost a total of about $50. If not you can send it to someone on this site to get it repaired for a couple of hundred bucks.
