vaughnop 0 Posted March 30, 2010 Report Share Posted March 30, 2010 I put 22's on my GS400 and now my navigation can keep up with my location....Do anyone know how to change the coefficient of distance???? Quote Link to post Share on other sites
intakerGS 0 Posted March 31, 2010 Report Share Posted March 31, 2010 You can adjust the NAV system manually by selecting 'menu' and then select 'NAV options'. You now can select 'Position' or 'Tyre replacement' (distance). So, if not done already, try this: Drive your car to a location which is known on the map (a reference point). Step 1. Calibrate 'Position': You can now adjust the map and move it to the desired direction by pressing the arrows (around the cursor). When the cursor is on the correct spot, press OK. A new screen comes up with two side arrows. You can now adjust the position of the car (in relation to the map). Press OK when done. Step 2. Calibrate 'Tyre-replacement' - 'Distance': When you press distance, the system will adjust it's position on the map. In general, the NAV system gets a part of it's info from the wheels and compensates automatically for distance when recieving a GPS signal (this can take some time and driving). However, I'm not sure if the system can compensate for the 22's. Perhaps you should drive a little and repeat former steps a few times. Quote Link to post Share on other sites
vaughnop 0 Posted April 1, 2010 Author Report Share Posted April 1, 2010 I tried that and it's still acting funny....I their's away to change the coefficient of distance by pushing the climate and the radio buttons but when I do it nothing happens... check this link out and tell me what you think...http://bananags.grantham-international.com/ click on #15 DIY Navigation service menu and you will see the screen I'm trying to get to.... Quote Link to post Share on other sites
intakerGS 0 Posted April 1, 2010 Report Share Posted April 1, 2010 You can try this: Hold the Climate and Audio controls while switching the parking lights on and off 3 or 4 times. This must be done immediately after turning the key on. A diagnostics screen should come up. Let me know if this works for you. Quote Link to post Share on other sites
vaughnop 0 Posted April 2, 2010 Author Report Share Posted April 2, 2010 It worked.... thanks a lot... I wouldn't had figured it out without your help... Now all I have to do is play with the coefficient until I get it right.. Once again....THANKS for you help.... Quote Link to post Share on other sites
intakerGS 0 Posted April 2, 2010 Report Share Posted April 2, 2010 Ur welcome, let us know if it worked in the end. Quote Link to post Share on other sites
