New to the forums but look forward to getting and providing whatever assistance i can to you all, have 1993 lexus ls 400 and i need to get a new instrument cluster for it, my gas tank indicator permanently shows im low/out of gas, the temp occasionally works but the RPM and the speedometer seem to be working just right, if any suggestions on where i should look can be provided it would be greatly appreciated, thanks folks. (websites or local spots in orlando, FL) :)
Salvage yards.
www.car-part.com
Or try a rebuilder to get yours repaired. Plenty online, just google it.
Mikado (IIRC)
you ship unit to them, they repair and ship back.
search for them, plenty of info around here somewhere.
Welcome to the club :cheers:
What should I do if I bought my car with the tachometer needle snapped off? I haven't had that needle for ages. Should I assume that I need to buy an intact used cluster and most likely get that repaired?
Depending on how much you love your car, since it is 20 years old and you don't really need a tach with an auto tranny, you could just leave as is. If you want it fixed then switch it out with a functioning salvage unit.
The gas tank gauge problem is normally due to a single capacitor failure on the cluster panel and 2 others give the flickering dash problem.
If you can DIY it can be sorted for a couple of $$ or get a local radio shop to fit them for you.
There are details on removing the cluster on www.lexls.com and cluster repair instructions on the web.
a
I had the similar problems ( light Flicker, the needles not getting illumunated, some had minor crack( this was way back 6 yrs ago and there was this JIM from Fresno who did mine for 200/- all tach needles replaced, so far "knock on wood" it has been perfect. This is his email address:- jimlwalker@sbcglobal.net. Give it a try
