alexpro Posted February 2, 2010 Posted February 2, 2010 Hi, the bulb stopped working now that I reached 50,000 miles. How does one go about replacing this bulb? I saw Gen 1 required that you remove the fender liner and the entire headlight assembly. I was able to remove the white tabbed plastic cover even though it is pretty tight in that area. I assume the assembly must be removed but I'm hoping it can be done without tampering with the bumper. Any help would be greatly appreciated. I would also like to know if anyone has purchased those lower priced HID bulbs from China advertised for about $25 each. A big difference from the Sylvania prices at the auto parts store that sell for $130.
cduluk Posted February 3, 2010 Posted February 3, 2010 Only replace your HID bulbs with the OEM philips D2S 85122. But yours might have 85122+ you need to check... Any other brand won't match color and won't even come CLOSE in intensity. Not to mention they won't last as long. Philips are the best, no doubt about it. You should be able to find a used one on ebay for less than $50, or a new pair for less than $130 shipped.
The G Man Posted February 3, 2010 Posted February 3, 2010 You should also change HIDs lights in pairs since the old one will be weaker and different color.
alexpro Posted February 3, 2010 Author Posted February 3, 2010 You should also change HIDs lights in pairs since the old one will be weaker and different color. Hi, I'm not even yet sure it is the bulb.. I still need to verify that it is the bulb by taking the working bulb from the driver's side and plugging it into the passenger side. I want to rule out the ballast. I just want to know how to remove the bulb...... there is nothing in the manual about it other than stating to take it back to the dealer. I spoke to my dealer and he said I may need to remove the bumper. I just would like to know the steps and if it can be done without removing the headlight assembly.
The G Man Posted February 3, 2010 Posted February 3, 2010 Sorry alexpro, I cannot help you. I never had to change the HID out in my old RX when we had it.
cduluk Posted February 4, 2010 Posted February 4, 2010 No need to remove the bumper to change the low beam bulb. You can gain access to the rear of the headlights from under the hood.... unless the standard Rx is MUCH different under the hood than the 400h is...
K.C. Posted May 23, 2010 Posted May 23, 2010 Only replace your HID bulbs with the OEM philips D2S 85122. But yours might have 85122+ you need to check... Any other brand won't match color and won't even come CLOSE in intensity. Not to mention they won't last as long. Philips are the best, no doubt about it. You should be able to find a used one on ebay for less than $50, or a new pair for less than $130 shipped. Greetings...What does the + (plus) indicate on the Philips D2S 85122+ HID blub? I am replacing the HID blub on my 2004 RX 330. This blub does not have a plus designation. Are the blubs interchangeable? TKS! always
cduluk Posted May 30, 2010 Posted May 30, 2010 The "+" indicates that it's a brighter bulb. It's also more yellow than the standard 85122. The bulbs "are" interchangeable, meaning switching them won't harm anything, but you will definitely notice the difference in output and color. My 08 Rx400h comes stock with 85122+, but i believe the older generation RX's came stock with the standard 85122. Personally i'd take the standard 85122 as they're a little more "white".
XenonDepot Posted June 18, 2010 Posted June 18, 2010 We actually sell Philips 85122 D2S HID bulbs that are brand new: http://www.kbcarstuff.com/SearchResults.asp?Search=philips+D2S+bulb&Search.x=0&Search.y=0 We have both the OEM 4300k bulbs and the 6000k Ultinon line. Let me know if you are interested as I will do my best to help out a Lexusownersclub member :-) Steve
jerryronchie Posted July 6, 2010 Posted July 6, 2010 As far as I know if the car doesn't come with HID you will find instructions in the manual and if it does come with HID then they don't telly you how to do it.
pezz Posted May 6, 2011 Posted May 6, 2011 How can I replace the low beam headlight on my Lexus RX 330?
98GS400Sleeper Posted August 1, 2011 Posted August 1, 2011 Hello fellow Lexus owners, I have a 98' GS400, I am trying to figure out how to replace the front turn signal bulb. I purchased the bulb however, when looking under the hood, it doesn't look as easy as finding the ballast, turning, pulling and replacing. Can anyone help make this process easy for me? Thank you in advance for your help. GS400Sleeper
Christinelove Posted September 23, 2011 Posted September 23, 2011 Replacing a burned-out bulb or headlight on your car is relatively easy. Cars will have one of two designs: On some cars, you replace
mleahy Posted August 23, 2012 Posted August 23, 2012 Really helpful. Thanks! One of the bulbs on my RX stopped working.
