artseattle Posted January 31, 2010 Share Posted January 31, 2010 I have a 1998 Lexus SC400 that runs great. Recently, there has been smell coming through the heater vents. The smell is not consistent and I can't really find a pattern. Sometimes it occurs right away, sometimes it's more noticeable when I'm idling. To me, it smells like I'm sticking my nose in a tin of band-aids. A friend says it smells more chemical, like paint thinner. Doesn't smell like burning or exhaust. No new brakes. All belts have been checked. I did have the exhaust system checked as well as a fluid compression check to rule out any leaks. Lexus says to bring it in when the smell is evident which is hard to do. If I do smell it, then when I crank up the heater with or without A/C, the smell seems stronger. I'd also say that it occurs about 25% of the time. No rhyme or reason that I can assess. Any guesses? Any other ways to narrow this down? Thanks! Quote Link to comment Share on other sites More sharing options...
eemueller Posted February 1, 2010 Share Posted February 1, 2010 Perhaps you have a small leak in the heater core. Does it smell like anti-freeze? Open your radiator cap and take a wiff. You could even try warming some in the microwave and trying the sniff test. Quote Link to comment Share on other sites More sharing options...
artseattle Posted February 13, 2010 Author Share Posted February 13, 2010 Problem solved. I had a failure with the "pulsation fuel damper" that was slowly dripping gas on to the side of my engine. Replaced at Lexus for $350 and so far... Symptoms were: occasionally smell of gas in the cabin of the car. AC/heat on or off didn't seem to matter. The smell came from the engine and flowed through the vents. Quote Link to comment Share on other sites More sharing options...
