Fog Lights Shorted?
ravig292
i have a 2000 ls400
my fog light bulbs stopped working i checked them in another car and they work
but i dont know what the problem is. i looked for the fuse but could not find it
does anyone know where the fuse is located? or if its not the fuse is it the wires that shorted?
i have a 2000 ls400
92% its the fuse
4% its a bad switch
3.9% it could be corroded bulb socket
0.1% its a shorted wire
Under the steering colume is the cover. It has three screws that you need to take out. They are hard to see, you need to look from the floor up to under the steering column area. Take those out and the plastic cover drops down. The fuse box is up on the left hand side. I think the fuse you are looking for is #2 (should be in your owners manual if you have it). I think it is the middle one on the bottom, I believe it is a 15 fuse. Hope this helps.
