yank30265 Posted January 13, 2010 Share Posted January 13, 2010 Been looking for a haynes or chilton for 90 ls400; no luck; i work at autozone and picked up a one yr scription for alldata been trying to save it on to a flash card but i think i need to b a geniuse to do it Quote Link to comment Share on other sites More sharing options...
dcfish Posted January 13, 2010 Share Posted January 13, 2010 Been looking for a haynes or chilton for 90 ls400; no luck; i work at autozone and picked up a one yr scription for alldata been trying to save it on to a flash card but i think i need to b a geniuse to do it Create a folder in your documents and name it LS manual or something you like. Save the alldata pdf's to that folder, When you have all the info you may need, Then copy the folder to the drive where you have the card inserted into. Bingo your done. Now make a backup or 2. ;) Quote Link to comment Share on other sites More sharing options...
yank30265 Posted January 13, 2010 Author Share Posted January 13, 2010 Been looking for a haynes or chilton for 90 ls400; no luck; i work at autozone and picked up a one yr scription for alldata been trying to save it on to a flash card but i think i need to b a geniuse to do it Create a folder in your documents and name it LS manual or something you like. Save the alldata pdf's to that folder, When you have all the info you may need, Then copy the folder to the drive where you have the card inserted into. Bingo your done. Now make a backup or 2. ;) thanks Ill get on that Quote Link to comment Share on other sites More sharing options...
dcfish Posted January 13, 2010 Share Posted January 13, 2010 Been looking for a haynes or chilton for 90 ls400; no luck; i work at autozone and picked up a one yr scription for alldata been trying to save it on to a flash card but i think i need to b a geniuse to do it Create a folder in your documents and name it LS manual or something you like. Save the alldata pdf's to that folder, When you have all the info you may need, Then copy the folder to the drive where you have the card inserted into. Bingo your done. Now make a backup or 2. ;) thanks Ill get on that Your Welcome... You owe me a beer Quote Link to comment Share on other sites More sharing options...
