HunterXRen Posted January 12, 2010 Share Posted January 12, 2010 Hey guys, I am having a major issue with my 04 IS300. The gas mileage has been horrific in the city compared to what it was getting previously. I have noticed a significant decrease of city mpg and I can visually see it going down tick by tick in maybe a fifteen minute commute from work. I used a up a quarter tank in one day, I think that is a bit excessive. My car is 59k mileage, but I thought spark plugs could have been an issue so I changed those with my timing belt, water pump and many other parts. I thought after changing my spark plugs everything would be fine again but it is not unfortunately. If anyone is having a similar problem or resolved this issue please reply back. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
smooth1 Posted January 14, 2010 Share Posted January 14, 2010 So how bad is the gas mileage your referring to? Did you pull the 02 sensors and check those also? What about your fuel injectors? Do you have any codes or a cel? Quote Link to comment Share on other sites More sharing options...
Parking17 Posted January 15, 2010 Share Posted January 15, 2010 What's the temp outside in Virginia? If it's like freezing cold outside, it might be running rich. I live in So. Cal but believe it or not last year, we had some very cold mornings and I noticed the same thing, temporarily. Quote Link to comment Share on other sites More sharing options...
HunterXRen Posted January 30, 2010 Author Share Posted January 30, 2010 Smooth1 I have no codes and I let a mechanic look at it and he has no clue also because no codes are showing up. He told me it's probably due to the cold weather outside, I am really hoping that is the situation. Quote Link to comment Share on other sites More sharing options...
izzy300 Posted February 9, 2010 Share Posted February 9, 2010 What kind of plugs did you use?? Iridiums are required for the 01s - probly the same for yours. Go to the dealer for any parts for your car, in other words...just a possibility if you let a friend do your plugs he might've used platinums which will change how the timing works. This in turn can affect mileage Quote Link to comment Share on other sites More sharing options...
izzy300 Posted February 9, 2010 Share Posted February 9, 2010 Premium gas, right??? Just making sure, sorry Quote Link to comment Share on other sites More sharing options...
