marylandjd Posted December 30, 2009 Share Posted December 30, 2009 The brakes on an ls460 have a wear pad sensor that triggers a warning light when the pads should be replaced.I can't find any mention of the light in the owners manual.Does anyone know which light it is? tx Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted December 31, 2009 Share Posted December 31, 2009 If it is like the 98-00 LS400 and the 01-06 LS430, there a warning message will be displayed in the "Multi-information display" between the tachometer and speedometer when a front or rear brake pad is worn down to the sensor. The message on my 00 LS400 says only "BRAKE WEAR" and doesn't say whether it is for the front or rear brake pads. I would hope that the message on the LS460 would be a little more descriptive but I don't know if it is. Quote Link to comment Share on other sites More sharing options...
