racwld1 Posted December 25, 2009 Share Posted December 25, 2009 i just had a new power steering pump installed on my 95 sc400, it still makes noise like a pump does when it is low of fluid, was something done wrong? i need help i can't figure it out, thanks. Quote Link to comment Share on other sites More sharing options...
lexmaxx Posted December 25, 2009 Share Posted December 25, 2009 i just had a new power steering pump installed on my 95 sc400, it still makes noise like a pump does when it is low of fluid, was something done wrong? i need help i can't figure it out, thanks. Are you sure its not the water pump? Some times the whining sound from the steering pump and water pump can sound the same. Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted December 26, 2009 Share Posted December 26, 2009 i just had a new power steering pump installed on my 95 sc400, it still makes noise like a pump does when it is low of fluid, was something done wrong? i need help i can't figure it out, thanks. Make sure the shop put in ATF fluiud and not PS fluid. If you're sure it's the pump, you could have air in the system. Don't have the links in front of me. Easy enough to find. Just search for the threads (more than one) and read up on how to get rid of the air. Basically putting the car on jacks and turning the steering wheel lock to lock 20 to 40 times (with the engine running of course), taking her out for a few hours and repeating if necessary over the course of several days. If this is not your prob, then the pump replacement is suspect. Quote Link to comment Share on other sites More sharing options...
jamesbondsc300 Posted December 26, 2009 Share Posted December 26, 2009 i just had a new power steering pump installed on my 95 sc400, it still makes noise like a pump does when it is low of fluid, was something done wrong? i need help i can't figure it out, thanks. I had the same problem. It turned out that my orginal pump did need replacing, but after i replaced it i still had that noise. I got out my trusty old mechanics stethoscope and found my alternator (bearings) to be bad. Quote Link to comment Share on other sites More sharing options...
