When driving the car this weekend on a wet surface, all of the sudden the car would make a screeching noise w/out putting on the brake or accelerating hard...just cruisin about 15 down the alley....anybody know anything about this??
wet surface like in rain soaked road or just damp?
If there was water on the road, could be that it splashed on one of the two belts and the belt then slipped on the pulley causeing a loud screaching noise. Similar to that of a loose belt on start up.
steviej
Could this noise possibly be from the brake wear indicators? Maybe it seems louder when, "just cruisin about 15 down the alley".
Thats my guess, the wear indicators always seem louder when going slow...
one reason you heard it is that you were going slow and the other is probably the sound bouncing off the narrow walls of the alley.
i had two distinct screeching episdoes on my 92 that are exactly like you describe.
the first situation was indeed the wear indicators. the 92 i bought had almost no brakes on the back. so bad they needed new rotors.
the second screech was because when I put the new rotors on, the pistons were seizing the shoes against the new rotors causing them and the new pads to head up to what I believe were fission sustaining temps (the wheel was so hot after driving i couldnt touch it :lol: ). my pads did not like that and would squeal just from the combination of the heat and the fact that the intense heat probably made the anti-squeal compound on the backs of the shoes wear out quickly.
so maybe check both of those things. I would guess it is brake related though...
also, does it stop when you apply the brake, light pressure or hard pressure?
it only happened 2 times....the road was really wet....and why would the brakes be wearing out when the car is only 2 yrs. old?????
You left absolutely NO information in your profile......especially the year of your car! Also, how many miles on your 2 year old car? :chairshot:
On a heavy vehicle like the Lexus with soft pads designed for quiet operation 2 years could easily be the brake life. Some LS owners dont even get 15,000 miles out of a set of brakes...
Also all depends on how you drive.
sorry about not specifying the model year...02...I've put that in some other topics but I didn't think to put it here....the car has about 10000 miles on it
I don't brake hard...unless there's a situation that calls for it....sometimes I don't brake early because I'm "testing" the brakes....maybe since it only happened once or twice it''s not really a big deal???
It's been pouring down rain today here in Texas and I was out driving and I heard the screeching noise....it was really loud...happened two times on the passenger side of the car.....still has only happened when it rains....just thought I would let yall know
And it does not happen when you're braking, does it go away when you brake?
I was not braking when it happened....oh and by the way I know earlier I said that the car had 10000 miles on it but it really has about 12200
The same thing happened to my car after driving threw water. I was told that i got a belt wet.
Lexus dealers will charge you anywhere from $150 to $350 to do an oil change, or what they call a "mini inspection" which includes looking at a lot of things, changing the oil, rotating the tires. If you just want an oil change best to take it elsewhere.
