Strut Oil Seepage Warning Sign ?
pbvhome
Hi,
My Lexus GX470 struts (some of them ) has minor seepage and dealer indicated a minimal seepage is normal. Is this warning sign that this would fail eventually or soon ? I was wondering this warrants any reparis within a year or two (for normal driving conditions, no off road commute) and I am asking to consider ext. warranty or not.. Appreciate your input
Thanks
Ok PV..this is the criteria the dealers usual check and come to decision. There are various stages. What you could do go by this method and do a physical inspection that will make sure the dealers are not taking your for a ride and you would know the Struts stage for replacement.Hope this helps.
shockabsorber_replacement_Criteria.pdf
