Tommy_B Posted November 26, 2009 Posted November 26, 2009 im planning on replacing the starter next week, but how hard would it be for me to replace the water pump also? and is there a tutorial for this anywhere?
billydpowell Posted November 26, 2009 Posted November 26, 2009 for the water pump and timing belt 2nd gen http://www.lextreme.com/timing.htm never put a starter on one of these.
Tommy_B Posted November 26, 2009 Author Posted November 26, 2009 for the water pump and timing belt 2nd gen http://www.lextreme.com/timing.htmnever put a starter on one of these. thanks for that site, its the same site i got the starter tutorial from. but do i have to do all that to just get the water pump out? because i do not need to change the timing belt.
landar Posted November 26, 2009 Posted November 26, 2009 for the water pump and timing belt 2nd gen http://www.lextreme.com/timing.htmnever put a starter on one of these. thanks for that site, its the same site i got the starter tutorial from. but do i have to do all that to just get the water pump out? because i do not need to change the timing belt. The short answer is Yes. You DO have to undo the timing belt to get the water pump out. You can reuse the timing belt if you like but if you go to all that trouble, you might as well just replace the TB at the same time. Not a trivial job. It is fairly involved.
curiousB Posted November 26, 2009 Posted November 26, 2009 Sorry. Lexus was kind enough to bury the water pump behind the timing belt. Its a timing belt job plus some in terms of effort. Unless your timing belt is very new you probably should replace it while you are in there.
billydpowell Posted November 27, 2009 Posted November 27, 2009 I just done one of my 97's a couple of months ago, and YES you will want to do it all at the same time, if you pay someone or do it yourself, lot of work and lot of time. my parts came from: http://www.store.partsdinosaur.com/page247.html everything fit perfect, and the car runs fantastic. NO LEAKS, NO ISSUES.
Tommy_B Posted November 27, 2009 Author Posted November 27, 2009 I just done one of my 97's a couple of months ago, and YES you will want to do it all at the same time, if you pay someone or do it yourself, lot of work and lot of time. my parts came from: http://www.store.partsdinosaur.com/page247.html everything fit perfect, and the car runs fantastic. NO LEAKS, NO ISSUES. thanks for that site. prices are fairly cheap. but does the water pump come with a new gasket?
billydpowell Posted November 27, 2009 Posted November 27, 2009 I just done one of my 97's a couple of months ago, and YES you will want to do it all at the same time, if you pay someone or do it yourself, lot of work and lot of time. my parts came from: http://www.store.partsdinosaur.com/page247.html everything fit perfect, and the car runs fantastic. NO LEAKS, NO ISSUES. thanks for that site. prices are fairly cheap. but does the water pump come with a new gasket? sure..
