RandySC400 Posted November 10, 2009 Share Posted November 10, 2009 Unbelievable best $46.00 I've ever spent!!! Mine was broke in 2 peices!!! The ride is simply amazing!!! Doing the motor mounts next!! Very excited and it was so easy!!! Quote Link to comment Share on other sites More sharing options...
amcdonal86 Posted November 10, 2009 Share Posted November 10, 2009 How long did it take you from start to finish? Including jacking the car up and taking it down! And soaking all of those bolts or whatever in PB Blaster? Quote Link to comment Share on other sites More sharing options...
90LS400Lexus Posted November 10, 2009 Share Posted November 10, 2009 Took my dad about 15 minutes on my 91. It helped some, but the motor mounts are so bad, its still unpleasant to drive. Motor mounts are much harder and time consuming on this car. More expensive mounts as well. Good luck! Quote Link to comment Share on other sites More sharing options...
RandySC400 Posted November 10, 2009 Author Share Posted November 10, 2009 honestly about 20-30 minutes!! all the bolts came off easlily but one so i put a wrench on it Quote Link to comment Share on other sites More sharing options...
happy rider Posted November 10, 2009 Share Posted November 10, 2009 Some pictures would be aplausiable, some one says the tranny mount might cause's the humming sound during the ride at certain speed and mine ls430 has it ;( Unbelievable best $46.00 I've ever spent!!! Mine was broke in 2 peices!!! The ride is simply amazing!!! Doing the motor mounts next!! Very excited and it was so easy!!! Quote Link to comment Share on other sites More sharing options...
RandySC400 Posted November 11, 2009 Author Share Posted November 11, 2009 it elimated a humming noise , viberations, loud clunks going over bumps n pot holes and it seems to shift tighter too... no pictures are needed. If you jack up your car and put it on jack stands... you will see a 2' mini cross member that is held on by 4 14mm bolts in the center of that cross member is 4 12mm bolts that bolt into the trannymount...just make sure that you jack up the tranny an inch or to before taking out ur crossmember bolts!!! oncce the crossmember is off you have 4 12mm bolts that hold the mount to the tranny!!! very easy and inexpensive i got my tranny mount at mybushings.com and i got 10% off for being a first time customer!!! Quote Link to comment Share on other sites More sharing options...
